Rock Krawler Truss
So it turns out I busted my factory axle. So I found a replacement, and was pretty excited because it already had the rock krawler HD LCA mounts, and the rock krawler truss, and had the same gearing I already had (and most important, was dirt cheap!). What I failed to realize was that the truss is designed to work for the 3-link long arm kits. I don't want to/cant afford to go to a long arm, so I want to just buy a new upper control arm bracket, trim the truss, and weld on a new bracket. (the axle is a JK dana 30). Does this sound like an OK plan, and does anyone have any direction in terms of where to get such a bracket and which one to get? Thanks!
I'm having a hell of a time finding the right bracket. I found a kit by currie thats like 150 bucks, but its for 3" OD tubing. I also found this http://www.4wd.com/Fabrication-Tools...pn=R%2fERE9986 which looks right, but it says its for the tj; not sure if the UCA mount actually changed between years
*edit* and of course now I look like a crazy spammer since this got moved from the fab section. whoops
I like that news! Any pointers in terms of where to look for that bracket? I feel like the factory mount is crazy thin and I'll destroy it cutting it off
