Rock light idea.......
Old Jul 29, 2007 | 07:02 AM
Duke's Avatar
Default Rock light idea.......
I have a Shrockwork winch stubby bumper on order. As soon as it gets here I intend to remove my stock bumper. The stock bumper has the flood lights in it.
Since the stubby appears to be just slightly wider than the frame I am thinking of welding on a bracket to the back of the bumper to install the factory fogs facing down and away from the front tires. This should be a very simple mod and work well lighting the trail at night without blinding my spotter using all factory hardware.
Thoughts?
Old Jul 29, 2007 | 12:09 PM
cajun-jk's Avatar
Iv'e had led's in about the same spot on my tj that worked great, I'm sure some of the west coast guys will comment. Sounds like a brilliant idea with good use of materials, my only question is will the wide pattern of the fog lamps be wide enough for such a close distance to the ground? I'm sure youve thought of this. If pointed straight down is a 0 degree reference point, @ what angle are you talking about?
Old Jul 29, 2007 | 02:48 PM
Duke's Avatar
Originally Posted by cajun-jk
......my only question is will the wide pattern of the fog lamps be wide enough for such a close distance to the ground? ................
Actually I have never even driven the JK at night, so I have no idea how bright or wide a beam the factory fogs are. Until my build is complete the Jk sits in the garage.
