JK-Forum.com - The top destination for Jeep JK and JL Wrangler news, rumors, and discussion (https://www.jk-forum.com/forums/)
-   Modified JK Tech (https://www.jk-forum.com/forums/modified-jk-tech-2/)
-   -   Rock rail suggestion - Stock Rubi Rock rails vs Rugged Ridge Rocker Guards (https://www.jk-forum.com/forums/modified-jk-tech-2/rock-rail-suggestion-stock-rubi-rock-rails-vs-rugged-ridge-rocker-guards-120604/)
Matador Feb 26, 2010 06:53 PM
OK this is what I found. Need opinions.
Stock Rubicon Rock rails for $175
http://www.quadratec.com/products/12112_221_07.htm
or
Rugged Ridge Rocker Guards for $340
http://www.quadratec.com/products/12052_0232_07.htm
both are slightly used.
Which one should I go with?
Matador Feb 27, 2010 12:49 PM
bump bump......
dlincoln91 Feb 27, 2010 12:53 PM
id get rugged ridge over the rubicons because ever once in a while you have those moments when your jeep slides off a rock and the side goes crashing into rocks or something like that and i would want them to protect the corner of the body all the way to the door.... just my .02
Rub61 Feb 27, 2010 01:02 PM
I came off of a rock a few weeks ago in my stock Rubicon and the right quarter panel in front of the door was deformed from the slider bending up. I am now looking for another alternative.
Matador Feb 27, 2010 01:19 PM
thanks for the input guys....sounds like the extra money would be worth the investment!
i think it's not a bad price...it's also in CDN funds...i'll try to get em a little cheaper :)
dlincoln91 Feb 27, 2010 01:25 PM
extra money in a situation like this allways has its benefits
runit3 Feb 27, 2010 02:41 PM
I would vote rugged ridge as well. My Rubirails have worked fine but only with a directly flush vertical impacts. If I slide off a rock it will be REALLY bad news. :fingerscrossed:
Stuka Feb 27, 2010 02:54 PM
The rugged ridge ones are nice because they stick out farther, but they won't prevent the rail from hitting the body if you come off a rock too hard, as they still mount to the body, and not to the frame.
If you want the best strength, go with a frame mounted rail.
ssunde1 Feb 27, 2010 03:23 PM
Yeap I don't wanna chance f'n up the body of the jeep so I'm goin off road evolutions rock sliders, they are welded to the frame, $399 aint a bad price either, although unless u weld, that's gonna cost a few $$ onto the cost of the sliders but I think its well worth it. Also the LoD, shrockworks mount to the frame, they are a little pricey though, and a long wait from what I hear. I recommend saving for some that are up to the job of taking a beating, should it happen. Just my $.02
superduperman86 Apr 18, 2010 10:16 AM
the Rugged Ridge "Rock Sliders" are mounted to the frame. their "side steps" are mounted to the body.
© 2026 MH Sub I, LLC dba Internet Brands
