rock rails
Old Nov 10, 2008 | 05:59 PM
rkcuscg's Avatar
Default rock rails
does anyone know if the four door rubicon rock rails can be modified to fit on the two door?
Old Nov 10, 2008 | 07:05 PM
RedneckJeep's Avatar
Sure. But by the time you pay someond to cut them apart with a plasma cutter and weld them together again, you'd have way more in them than what you could have bought some for.
Old Nov 10, 2008 | 09:44 PM
wayoflife's Avatar
JK-Forum Founder
the mounting points are different enough to be a problem and the curve of the body will not be the same.
Old Nov 11, 2008 | 01:33 AM
pearl-drum-man's Avatar
Agree with the others, they're not that expensive new, and there is a good possibility you could find a take off set cheap, would be much better way to go than try and modify a set off the Unlimited.
Old Nov 11, 2008 | 01:37 AM
Piginajeep's Avatar
good point,
I'll have a set off mine soon..
basically new...
