rock rails install bolt size ?
Old Mar 8, 2008 | 11:55 AM
blockrockin's Avatar
Default rock rails install bolt size ?
hi i bought some factory rock rails, without the 6 bolts i need for install . i was wondering if anyone knew what size bolts i need. i asume that they fit into the 3 holes i found on each side covered by tape ? if anyone knows that would be a great help ! thanks alote !
Old Mar 8, 2008 | 01:44 PM
dociain's Avatar
Default rock rail bolt size
Two bolt sizes are used.The smaller bolts are 10mm and need a torque of 8 ft lbs.The larger bolts are 13mm and need a torque of 16 ft lbs.This is from the Mopar instruction sheet.Watch when fitting not to drop rails as they will give you a bit of a nasty headache!!
Old Mar 8, 2008 | 02:33 PM
great thanks for ur help
Old Mar 8, 2008 | 05:41 PM
does anyone happen to have a pic of their factory rock rails from underneth where the bolts are attached , i just want to see a pic to make sure i install then correctly ,thanks alote !
Old Mar 8, 2008 | 08:38 PM
cjsdad's Avatar
You can only put them on one way. Place the 6 smaller bolts through the pinch seam and the 3 larger holes will line up under the body. I tighten them hand tight as not to loosen and come off.
Old Mar 9, 2008 | 05:50 AM
thanks for the help. i have the the smaller bolts and nuts the bigger ones i dont have . that is what i need. someone said 13 mm i guess that is the size of the head ? what size is the hole ? thanks alote
Old Mar 9, 2008 | 07:13 AM
cjsdad's Avatar
not sure on the size, but I got some xtra ones from dealer. They gave me one for free, they can't be that expensive. They are the same bolt used for the side steps.
Old Mar 9, 2008 | 07:29 AM
hey good idea. maybe ill swing by and see if they have any extras.
