Rock Slider/Step/Advise
Old 02-27-2010, 10:27 AM
Brian-08 Rubicon's Avatar
Default Rock Slider/Step/Advise
As the 5.5 RK lift and 37's have been ordered.....
I am looking for some opinions on a rock slider that I can tell the wife is a step as well, if you know what I mean.
I am considering the shockworks and the river raider ones at this time but also open to suggestions.
Can they actually help someone get in Wife/Kid as a step or is that a stretch.
What I would REALLY like is a automatic hide away step like the new Ford pick up has but cant find one.
I would also like to know about wcich is best a frame or body mounted one and pros cone of each
Thanks in advance for the advice.
B
ID:	37856   Click image for larger version
Name:	River Raider4doorsliders.jpg
ID:	37857   Click image for larger version
Name:	Ford Side step.jpg
Old 02-27-2010, 10:54 AM
Piginajeep's Avatar
With that high if a lift and tires, you won't have a usable step,
Mbrp has a decent one with removable steps when you go Offroad.
If your going to tube mount, ie drill through the tub get the purejeeps. They actually tie all the layers of the tub together and don't just hang on the putter sheet metal like the riveraider
Old 02-27-2010, 11:30 AM
Thanks! The MBRP looks good, I have there cat back exhaust on the challenger
Old 02-27-2010, 11:51 AM
spinlock's Avatar
There are a few other option in this thread:
https://www.jk-forum.com/forums/show...=106608&page=2
But if you want both sliders and lower steps, I think the MBRP unit is the cleanest option.
Old 02-27-2010, 12:03 PM
Curiosity's Avatar
I've got the same basic setup as you (35's w/ a fabtech 3" lift) and most rock rails are just a bit higher than the bottom of the tub anyway. My wife still likes the side step because she can more climb into the jeep rather than jump into it. I like it b/c it gives me a little more comfort when the doors come off in the summer and I can use it as a ledge to jump to the side of the trail rather than stepping down into the mud and walking to the side of the trail.
If you know what you want and have some experience w/ welding, make your own... if not, having a set of custom rock rails w/ a step fabbed will probably be about the same price as some of the premade rock rails on the market for the JK.
Good luck and post what you find... I'm going to weld up a set of rockrails w/ step this spring or summer and am still looking for other features I might want.
Old 02-28-2010, 02:41 AM
Mark Doiron's Avatar
Originally Posted by Brian-08 Rubicon
... I am considering the shockworks ...
I have the Shrockworks rock rails (and front bumper and rear bumper/et al ready to be installed) and I love them. I use the rock rails as a step, but I don't have tires or lift as large as yours. At your configuration, the rock rail may be too high to be a step from shorter people/small kids. Also, the semi-gloss paint on them (can't speak to other available finishes) can get a bit slippery when wet. TORN has stuck some friction tape on his that he picked up at Lowe's. The only thing I don't like about that is that it scratches the back of my leg when exiting his Jeep and I'm wearing short pants. LOL.
Also, anytime anyone is interested in Shrockworks I like to point out that their performance and quality is second to no one. But, they do charge your credit card when you order, and it usually takes them months to deliver product. If that is unappealing to you, contact Screamin' Lizard, also a forum sponsor, because they may be able to work better with you on Shrockworks products. Bottom line: If I had to do it all over again, I would.
Old 02-28-2010, 05:39 AM
David C. Brown's Avatar
Default Rock slider/step/advice
I feel that the "Treks Offroad Equipment" boat sided rock sliders are the best if you do any serious wheeling. They protect your body mounts and eliminates any places that rocks could get you hung up on. They mount to the frame. The thin sheet metal of the body is no place to mount anything that will add a stress. I have read some posts where guys complained that when they removed sliders from their rig, all the holes had elongated and tore out the mounting hardware. I have witnessed another brand (not Jeep) vehicle cave in his entire rocker panel when his slider needed to function while going over a bolder. The built-in step acts like a lever to multiply the forces and cause damage. My TJ had heavier gaged metal, and I was able to sandwich it between another piece of metal on the inside of the vehicle to add strength....no way that I know of to do this with my JK Rubicon. I use "Redneck Concepts" stirrup style step (portable) for my wife to get into the Jeep.
Old 02-28-2010, 06:47 AM
Piginajeep's Avatar
First you cant compare a none jeep to a Jeep for rocker protection,
secondly not all Body rockers are mounted just on the sheet metal, I would venture to say, the ones that elongated were mounted this way.
much like the TJ, you can mount through all 4 layers of the JK and sandwich the 4 layers, plus the rockers and make a very strong mount. It can be done!
I wrecked my first JK, I hit a car head on. It bent the tub to the side and stopped at the Purejeep rockers. I pulled the rockers off. The holes were fine, they were no elongated. As a matter of fact, the Rockers were a bitch to remove because of the way the mount on the tub.
Old 02-28-2010, 02:52 PM
Thanks again....the MBRP ones are sweet as well, they say each step only takes a minute to remove/install.
Anyone have any experience with them?
Old 02-28-2010, 03:06 PM
jeepnick's Avatar
I put the purejeeps on today, they look awesome very happy with my choice
Quick Reply: Rock Slider/Step/Advise
