Rock Solid Fabs JKuggy
Old Jul 27, 2011 | 08:16 PM
RokinRubi's Avatar
Default Rock Solid Fabs JKuggy
So the next stage of the jk is beginning. I'm taking my jeep to Rock Solid Fabs ( buddy owns it) to have a front ford hp d60 with rcvs, detroit, high steer knuckles, full hydro, and 4 link truss.
The rear will be a 14 bolt with disk brake conversion, detroit and 4 link truss pretty simple.
Then comes the 4 link going to be using Rough Stuff 1.25 monster heim joints and DOM tubing
For suspension he is building custom mounts that will be tied into the cage and will be sporting some 18" travel ORI struts in the front and 16" in the rear.
Last but not least a built 6.0 supercharged 500hp with 4l80e transmission.
Here is what it looks like now
Here is the first pics of the build
14 bolt rear axle
rough stuff 3/8 welded diff cover and caliper mounts
RokinRubi's Avatar
here are some pics from this past weekend before I dropped it off to get torn down
:smokin:
Old Jul 27, 2011 | 08:17 PM
RokinRubi's Avatar
Here is a pick of the axle with all the drums gone. And a set of 35 spine outers for the d60 going in the front. I've decided to save a little money and run stock shafts till I break one
Old Jul 27, 2011 | 08:19 PM
RokinRubi's Avatar
pics from this weekend
We did some diggin in the wiring and found out with the engine computer removed the jeeps BCM is still working and allows the radio, lights, turn signals, ect to function normally. So all we have to wire up are some simple controls, becuase the chevy motor and trans will run off the stand alone harness and bam we are done :shaking:
RokinRubi's Avatar
Here is an update we got the motor torn down, axle unloaded, and Judy got cleaned before Fab work started
Old Jul 27, 2011 | 08:21 PM
RokinRubi's Avatar
Just picked this bad boy up. Picking up the front truss this week. Hopefully Ballistic fans wont take 10 years to get me my brackets but I'm not holding my breath.
Here are some more goodies I picked up at BTF
These are all the frame and 4 link brackets we will need. Some sweet looking stuff.
Upper frame mounts
lower axle link mounts will be gusseted more
lower 4 link frame mount yes we are now doing a double triangulated suspension
14 bolt Detroit locker that goes inside the carrier
Old Jul 27, 2011 | 08:26 PM
PainKiller's Avatar
NICE !!! can't wait to see the finished product keep the pictures coming
did you have to make any modifications to get the soundbar mounted up front like that ?
Old Jul 27, 2011 | 08:33 PM
RokinRubi's Avatar
Will do.. Sure didn't just moved it and used some new bolts to bolt it in. The stock cage will be going and new one will be built. It will be sporting some wake tower speakers
Old Jul 27, 2011 | 08:51 PM
PainKiller's Avatar
wakeboard speakers are the way to go especially since they are weatherproof
BStelling's Avatar
I love these kinds of builds! Just balls to wall outrageous work! I love it Keep the pictures coming for sure.
