Rock trac Transfer Case Swap
I want to swap the Command Trac NVG241 GEN 11 Transfer case from my Sahara 4x4 Unlimited 07 to Rock Trac NVG241OR Transfer case from a Rubicon.
The cost for just the Rock trac NVG241 tcase is $2300 :eek2: What I want to know has any one done this before???? What else I need to get the swap done correctly. So far based on my research here are the differences The Sahara and rubicon both use NVG241 Tcase with same size and length. The main difference is ROCK TRAC NVG241OR 4:1 Reduction Gears 32 Spline Front & Rear Output Shafts Larger Oil Pump Fixed Rear Yoke Command Trac NVG241 2:72:1 Reduction Gears Rubicon has Front & Rear 32 Spline and Sahara has Front D30 27 Spline and Rear D44 30 Spline. (Will this make any issue) JB Conversion jbconversions.com/pages/ has asked me to find out the input shaft length of the tcase. :D Does anybody know this. Your help will be really appreciated. |
ANYONE any idea any advise i am sure there are many experts and pros who can help me over here
Why not go with an ATLAS if you're going to put that much money into it?
I saw a 241R get swapped on Saturday.
1) Drop out old t-case 2) Pull harmonic dampner from 241R, put on new fixed yoke 3) Pull old yoke from front output shaft, put on new yoke. 4) Mount T-case 5) Mount T-case support 6) Connect D-shafts The whole thing took 45 mins. Andy |
Do you have a link to it for more details. R u talking about the Command Track NVG241 on an x some more info please
I read some posts on ATLAS but not sure how much the are and again what will it require to do the swap.
Do you think I should go for atlas but what about the speed sensors, computer stuff etc |
get a 2 speed atlas, they are ~2kish and much stronger than a stock case
For the same money put in a 2 speed atlas.........5 times as strong and one less thing that is Mopar under your Jeep to worry about...LOL
Originally Posted by onsafari
(Post 162060)
stak4x4.com/2speed.htm |
Originally Posted by DELL
(Post 161999)
Andy |
