Rockhard Skidplate Problem
Hey just wanted you guys to know if you have a Rockhard gas tank skidplate on your 4 door, trim the section where it bolts to the gas tank by the rear driveline yoke. This is what happened to me in the Rubicon a couple of weeks ago. As most of you that were there know.
It broke the ear off the drive shaft. What you are looking at is a new rear yoke. Look at the skid plate and you can see where I hit it several times when I articulated.
I have to admit I thought it was just the tires rubbing the rear fender. My bad. Definitely can ruin your day. I guess I'm the only one that didn't know to trim it there. Wanted to share so this doesn't happen to you.
Thanks again to everyone that helped me!!
Oh and BTW Liz if this is in the wrong spot I'm sorry, Just wanted Norcal to see what happened. Thanks Larry
I just removed the skid, used a cutoff wheel to trim away enough to allow clearence, I also adjusted the rear trackbar out to move the axle more to the driverside. No problems since then.
I have heard of issues with this type of rubbing with other brands of skids as well. In that case it was a 2 door.
I had the same issue. I ground it off. Now it looks like yours but doesn't hit anymore. Wasn't a problem for mine until the lift got bgger than 4"
My wife has Rock Hard, her's doesn't run. She has a 3" lift. She is getting evo double throw downs next week. We'll see if it rubs. If so more grinding......
