Rocks stuck in rotor problem. Please Help
I have MB72 15" rims with BFG KM2's and ever since I got them I can not drive down a gravle road without getting rocks stuck in my rotors. They will squeel and squeek so loud and it sound horrible and I have to take my tire off to get them out. Has anyone else had this problem as bad as I do? Is there any way to stop this from happening?
Are they stuck in between the wheel and rotor, or pad and rotor? If it's the wheel, a set of wheel spacers should push them away enough to clear the rocks. If it's the pad, I don't have a solution.
I have 3.75 backspacing and they alread stick out past my fenders so I really don't want to do spacers. Thanks tho
I get the occasional little stone stuck between rotor and pad. As soon as I hear the squeal I just stop put the jeep in reverse for a few feet and this normally clears it. Should work for stones stuck between rim and caliper also
Originally Posted by gint2
Just cause they fit don't mean they work well. I have seen spinners and 22" on JK, makes it just as wrong.
Search Quadratec Black Rock for an inexpensive alloy rim
Good luck... Get creative like a dust shield and bend it backwards??? I would op for a larger rim, you only need 1/2 tire dia for rim size, ie 32" tire = 16" rim
