rolling squeak coming from the fronted
Old Jan 28, 2018 | 11:58 AM
jaydcljr's Avatar
Default rolling squeak coming from the fronted
ok I am at my wits end . I have the like rolling squeak coming from my front end . I thought it might have been a hub bearing going and replaced the universal joint on the driver side and I also replaced the Caliber thinking that it might be sticking. I took it all down today checked for areas like the back plate to see if it is rubbing did not see anything to indicate a rub. I check nuts and bolts for tightness to make sure I did not have anything that was loss. I am not sure where to go from here. I checked the drive shafts they seem to be tight and the only thing that I can think that it could be is a bearing in the Diff housing itself. Can any one give me some ideas where to go from here. It is a high pitch like a bearing is going bad ..... One more thing is that this doesn't start till after I have been on the road for a while going at speed. After it has been sitting for a while and then I drive it the wheel squeak will come back. I checked the brakes they are new and the rotors are new all the way around. This noise did not start because of the brakes because they have been on for over a month and a half and the squeak only started about 7 to 10 days ago. The is more like a chirp type squeal like a bearing. only hear it when driving does not change when I go over a bump or when I turn the wheel.
Thanks
Old Jan 28, 2018 | 01:24 PM
jaydcljr's Avatar
I was thinking of replacing the CV joint in the front drive shaft. What I am thinking is that the noise is traveling up the shaft to the front end. I am really stumped by this one. The noise is driving me nuts.
Old Jan 29, 2018 | 07:20 AM
Monte417's Avatar
Best not to guess and throw parts at it. Start by jacking up the front end spinning each tire individually as it can be one or both of your unit bearings. If no noise from the unit bearings then remove your front driveshaft and go for a drive to see if the noise is still present.
Old Feb 11, 2018 | 05:02 PM
jaydcljr's Avatar
Noise is still there and getting worse I think or louder. removing the drive shaft did not rid me of the issue. It seems to be coming from the middle of the jeep towards the rear. It is very noticeable at slow roll but only after I have been driving at normal speed for a few miles.
Old Feb 12, 2018 | 03:26 PM
jaydcljr's Avatar
ok update changed out the cv joints in the rear drive shaft and still have this damn rolling squeak. It seems to be getting louder and louder. I am my wits end on this one. Checked the new rotors they are not hitting anything check all the pads they seem fine. I put the jeep up on jack stands rolled all the tires don't hear any noise at all. I am about ready to put a bullet in this damn thing. Could this be a bearing going but that would be a whin and if the pinion bearing were going to you would hear a really loud hum .So this is just not making any sense what so ever. I have torn this this apart except for changing out the e brakes but they seem fine .An they would squeak all the time I would believe . check the axles to make sure they are not bent they seem to be running true and not touching anything. Any help you can give me would be greatly appreciated. Also the u joints on front driver side have been change as well as the wheel hub.
Old Feb 28, 2018 | 06:47 PM
jaydcljr's Avatar
ok update Changed the fluids in the front end and reinstalled the front and rear brakes the squeak seem to disappear when I replaced the fluid in the fronted. ok after about 100 miles the squeak is back. The brakes seems to be ok tested the rotor and caliber don't see anything out of normal. I am going to get a new set of front brakes pads and hardware to see if that is causing the issue. ...... The brakes I currently have are z36 prostop with slotted rotors currently.
Old Mar 1, 2018 | 07:33 PM
jsukey's Avatar
Maybe a brake pad that was dragging?
Old Mar 3, 2018 | 02:44 PM
jaydcljr's Avatar
all new Calibers as of today and brake pads still have the squeak coming from under the jeep . I am starting to think it is the Transfer case or maybe the trans. It is really hard to pin point. I have tested and tested it and still no locating the issue... I am thinking about taking it to a drive line specialist here in the area. I really don't want to toss more money at it unless we can locate the issue. I have had several people drive it and several mechanic also and they have no clue where it is coming from. I am thinking that just driving it till it fails but we all know that never ends well but I might have no other option.
Old Mar 3, 2018 | 03:05 PM
jsukey's Avatar
How about jacking up all 4 corners on jackstands, then very carefully trying to put it in gear to get everything moving slowly while in gear to see if you can pinpoint where the noise is coming from? I would advise you not to be underneath or in front of the Jeep at all. Have someone in the drivers seat ready to apply the brakes in case one of the jackstands topples. If you can narrow it down to one wheel or wherever it's at, that would be better than just throwing money at it. Not sure if you are locked up or not, but if you are...engage your lockers and try to freespin your tires with the engine off. That could potentially help you rule out the trans/transfer case.
Old Mar 5, 2018 | 07:08 AM
BoraBora's Avatar
Do you offroad at all?
Take both rear tires off, and check to make sure your axle flanges aren't bent. Bent flanges will cause a squeak just as you described. Does it squeak when you're hitting the brakes?
Take the rotor and caliper off, and turn the axle shaft a few full turns with your hand while visually inspecting it. Here's what to look for:
