Roof rack idea
Old Jan 14, 2009 | 10:45 PM
Lo2aY's Avatar
That's a very cool Rack
The only thing that I would worry about is the mounting point on the back.
It looks like it goes on the bumper?
serveapurpose
That's one crazy ass rack
what size lights are those in the rendering?
would you make one for the 4dr
we are best friends :p
Old Jan 15, 2009 | 11:56 AM
Jeeper-Chris's Avatar
Originally Posted by MBAR741028
Does anyone have the wild boar rack. Or has anyone seen them in person. Just looking for some feed back on them. Thanks
Since you asked, I have the Wildboar. Definitely like it so far.
Old Jan 15, 2009 | 01:05 PM
serveapurpose's Avatar
Sponsoring Vendor
Off Road Evolution Rep
Originally Posted by Lo2aY
serveapurpose
The lights in the wonderful paint.net drawing are 6 inch KC slims. I'm not sure yet what kinda room we have to work with across the front. We plan on starting the project in early spring. I don't think it will be a problem getting something for the 4dr. worked up. May have to go look at someones for connection points for the rear of the basket.
Old Jan 15, 2009 | 01:17 PM
JdTms11's Avatar
Originally Posted by eisenjj
Yeah if it is the stock POS! Would not be a problem if it were a substantial aftermarket piece.
yeah no the plan would be for it to attach to an aftermarket bumper, unless i just rotated the lower mounts 90 degrees in toward the body of the jeep and mounted it that way, but the plan is to bolt and weld it to an aftermarket bumper
Old Mar 5, 2010 | 09:30 PM
AREA 13's Avatar
Originally Posted by JdTms11
since im probably never going to get around to this in the near future i wanted to share what i have come up with for a roof rack/ light bar combination. something to solve my issues with fitment since im running a river raiders snorkel.
if you would like to view the rack in 3D go to Google sketchup's web site, download the free version and then PM me an ill send you the file.
heres the pics
This would but built out of aluminum square tubing and have expanded aluminum sheets (what we all use for the grill mod) as a deck. my thinking behind the 2 baskets was 1. i like the look of a lower 8" ish deep front basket with a 12"-14" ish deep basket up behind it and 2. the deeper back basket will hold bulkyer cargo more sequrely, the front portion of the rear basket can hold bags snugly under the angled part of it and the front basket can be used for what ever else i dunno.
the front of the rack would attach to a custom light bar, which is actually a borrowed idea from someone else here on the forum. the light bar attaches via windshield brackets, whats not show in what i have done so far is on the passenger side the tubing for the light bar would need to come up along the windshield then bend 90 degrees in and then 90 back up then 90 back in and across to the other side, this allows the light bar to clear my RR snorkel.
the light bar would have two clamp style latches that would latch down on the rack to lok it in place.
Top view showing the cross members, picture a sheet of expanded aluminum welded on this.
detail view of the rear upper hinge. this in conguntion with the lower hinge allow the removal of the soft top. the upper hinge would also be able to flip the rack 180 degreese and turn into a 'shelter' of sorts
lower hinge detail. only allows the rack to rock back a little, then it could be fliped over and proped up to create an awning.
lower mount. consisting of a plate welded to the lower hinge assembly and would attach near the outer edeges of a bumper. a lower plate with bolts attached would esentialy clamp the rack down. for a metal bumper i would just weld it to it.
this is just a start, im still changing things around and tweaking what i have here so far plus adding new stuff as i go. any and all constructive critisisum is welcome and encouraged.
bonus pics
again i can send anyone with google sketchup the file so they can look at it in 3D (if i do end up sending it none of the measurements are exact i did this by eye with a 6' human silhouette to judge every thing off of, the only thing relatively close to being the right scale is the size and shape of the windshield bracket i did up.)
That's the perfect rack I have been looking for and it's not even in production. I'm looking for a 2inch tublular style full size rack (tilt capable) and wiremesh flooring or tubular flooring where wiremesh can be added. Everyone does half racks, or full racks that drill into the body... The reason I don't want o dril in the body is the RACK won't last forever, esp. in the East cost with rain, salt and snow. LOVE THE RACK... wish manufactures would build soething like it!
Old Mar 7, 2010 | 04:07 PM
joelmahoney's Avatar
Looks very cool. It seems that the bend at the top of the rear upright may limit rotating a full 180* for shelter mode. Maybe the standoff distance is sufficient, hard to tell.
I couldn't tell from your sketch if they are included, but you should incorporate some kind of a pin at the lower hinge on the rear upright to lock it in the upright position. if both upper and lower rear pivots are free, you will be relying solely on the light bar to locate the rack and contents forward and backward. that's a lot of leverage on the windshield plate bolts.
Hope you get around to putting this together
Joel
Old Mar 7, 2010 | 05:31 PM
Mtn Man's Avatar
Cool idea man
Old Mar 8, 2010 | 12:46 PM
Cortland's Avatar
Originally Posted by serveapurpose
I like to see someone working on their own creation. Very nice sketch! My Brother in law and I are working on a 2dr x7 no drill lightbar and quick release no drill 1/2 basket very soon. Us 2dr. guys are limited space when looking to go on camping runs with sufficient gear. Here is a quick mock up of our idea, sorry mine are not as high quality as yours.
This thing looks badass!
