Rotated my tires..hmmmm
Old Sep 27, 2012 | 02:03 PM
stevedolce's Avatar
Default Rotated my tires..hmmmm
Just rotated my tires (Goodyear duratracs 315/75/16) when i took jeep for a drive I noticed a slight hum /road noise. Last rotation was probably 10k miles ago. I assume there's a little noise since treads are now going in different direction? The GYDTs are pretty quiet tires..maybe I was LOOKING for noise? And a side note--you torque me to 95 ft lbs..right
And a side note.
Old Sep 27, 2012 | 02:05 PM
mattbarton15's Avatar
I think I torqued to 110 or 105
Old Sep 27, 2012 | 02:06 PM
dman1116's Avatar
Totally typical for a lil noise on new rotation.
Emmeljk11's Avatar
95 lbs i believe
Old Sep 27, 2012 | 05:00 PM
aldaman's Avatar
Originally Posted by Emmeljk11
95 lbs i believe
x2, 95 ft/lbs is the recommended torque settings....
Old Sep 27, 2012 | 05:57 PM
jcraw3's Avatar
My Duratracs have picked up a little extra hum as they've gotten some wear on them. Still not very loud though. I'm about 23,000 miles into them now.
Old Sep 28, 2012 | 03:29 AM
stevedolce's Avatar
I'm about to cross 29k on mine. Still holding up well.. In about 100 miles ill re-torque em.
Old Sep 28, 2012 | 04:31 AM
AU Bronc N JK's Avatar
Tire hum after a rotation is pretty typical. Depending on how you had them rotated, you have various tread lugs on each tire that do not have the same contact patch on the ground as they did prior to the rotation. Give it a few hundred or even a 1,000 miles and the tread will wear evenly and the road noise should reduce!
Luke
Old Sep 28, 2012 | 10:43 AM
Rooster76's Avatar
X3 that's the recommended torque. I have heard that they are put on at 110 at the factory. You need to be careful no to over torque aluminum wheels or you can damage them.
Smart
SIDE NOTE
G Rearward cross (on right) is the preferred method, but if you have something that's working for you just stick with it. Figured I would post it hear for people who find the thread with a search.
Last edited by Rooster76; Sep 28, 2012 at 10:45 AM. Reason: picture was too smal to make outl
