Rough Country 4" Lift
Old Dec 12, 2008 | 10:58 AM
  #21
DuDz40VT's Avatar
Looks great man, congrats on getting it on, can't wait to order the kit myself.
Side note how much did it cost to line x your jeeP?
Old Dec 12, 2008 | 11:39 AM
  #22
Dr.McNinja's Avatar
About $450. I had to remove all the hardware and help him mask it off though.
Old Dec 12, 2008 | 12:16 PM
  #23
Jusaplaya's Avatar
Ordered my kit today. I am gonna give it a try with the adjustable trackbar and no drop pitman. If I don't like the way it rides I am gonna put it on. No worries either way. Hopefully my lower control arms and trackbars will ship soon. I ordered them Wednesday.. Looks good Dr.McNinja. I got same color as you. What kinda tires are you running?
Old Dec 12, 2008 | 12:34 PM
  #24
Dr.McNinja's Avatar
Stock Rubicon BFG KMs. They're a hold out until I order some 37s, hopefully.
Old Dec 12, 2008 | 04:53 PM
  #25
Jusaplaya's Avatar
Thanks again Dr.McNinja.
Old Dec 13, 2008 | 05:05 AM
  #26
Dr.McNinja's Avatar
To anyone out there.
So I have my wheel centered (at least enough that the ESP doesn't light up around corners, etc, I didn't use lasers to align the thing).
Now if I hold the wheel in the middle, it goes straight. But if I let go, it drifts to the right (Jeep, wheel, everything). It did this a little before the lift as well. Granted, I would rather it drift right than left, but is there anything I need to be checking?
Old Dec 13, 2008 | 07:11 AM
  #27
Bodo's Avatar
The trackbar doesn't connect to the dropped pittman arm. The draglink does. I would think that not using the dropped pittman would put the draglink at too steep of an angle and possibly put too much stress on the steering shaft. I could be wrong on this and hopefully someone with more knowledge would chime in. I did use the dropped arm and haven't had any issues at all.
Old Dec 13, 2008 | 07:32 AM
  #28
Dr.McNinja's Avatar
That's what I'm reading. Not dropping your pitman arm is what causes bumpsteer. Lowering it makes the geometry work better.
Old Dec 13, 2008 | 12:07 PM
  #29
Jusaplaya's Avatar
Ninja: Did you do anything to lower control arms? Do you have the adjustable arms installed yet. That might be the problem.. I don't think your suppose to use an adjustable trackbar with a drop pitman. The bracket takes care of keeping the factory trackbar and draglink parrallel. I might be wrong though. I talked to Ben yesterday and he said it should work to use an adjustable trackbar to recenter the front.
Old Dec 13, 2008 | 12:13 PM
  #30
Dr.McNinja's Avatar
Adjustable arms aren't here yet. The axle is pretty centered, since I have the trackbar bracket on there. However, my bracket certainly isn't 4 inches lower than the stock one, but the pitman arm is pretty close in drop to it. The adjustable length should keep it parallel, but shorter so you shift the axle back over, AFAIK.
I haven't adjusted the toe in any, but I didn't change tires, so I didn't think I needed to just yet. It shouldn't have changed any. Maybe I just notice it more with the camber being off.
