Rough Country 4IN JEEP X-SERIES SUSPENSION LIFT KIT
Old Dec 12, 2014 | 08:28 PM
truxkt's Avatar
Question Rough Country 4IN JEEP X-SERIES SUSPENSION LIFT KIT
thinking about lifting my daily/weekend warrior 2014 jk rubicon x with this lift kits. trying to run 37 tires with flat fenders.
any reviews or thoughts? recommendation?
I would need some guidence with 4in lift project.
thanks.
Old Dec 12, 2014 | 11:47 PM
nthinuf's Avatar
Hit the back arrow a few times. Stuck right to the top of this modified area are the FAQ's and Thoughts on Lifts threads. (If you are on a phone, well, I forget what folder they are in, but you should still be able to find them.)
So, start by getting a handle on what each of the specific components in your new lift actually does. Then get a handle on at what heights people start wanting them. And what issues lifting causes that make those components wanted/needed. Look for things like: caster correction, pro's/con's of CAM BOLTS, steering angle correction, pro's/con's of a DROP PITMAN, the need for new driveshafts, why you want your swaybars to remain level, how much bumpstop you will want for your specific build, extended brakelines/brackets, backspacing requirements for the 37's, etc, etc. (note the capitalized ones!! They are in that lift...)
And, be prepared for a lot of people telling you that a 'JK' does not need 4 inches & flats to run 37's...
