Rough Country squeak...
Old Jan 18, 2009 | 10:50 AM
JK-KJ's Avatar
Default Rough Country squeak...
after installing the RC 2.5" coils with the 2.2 shocks i have noticed a tiny annoying squeak in the rear.....i'm thinking its te shocks. anyone else have this??
Old Jan 18, 2009 | 11:36 AM
sacdaddy03's Avatar
I don't....But I don't even have a 1000miles on my lift! Try putting some lube on the shock shaft and some grease on the bushings!
Old Jan 18, 2009 | 11:42 AM
JK-KJ's Avatar
yeah i only have about 100 miles on mine so far....but im gonna try to figure it out when i get home....its annoying!! what about maybe the control arm bushings? i'll look at that too.
Old Jan 18, 2009 | 12:11 PM
sacdaddy03's Avatar
It wouldn't hurt...check everything that was a rubber bushing while your look!
Old Jan 18, 2009 | 12:12 PM
jkolb08's Avatar
I keep hearing the same type of noise towards the rear I just had the 2.5" Teraflex lift installed. Cant seem to find exactly where its coming from though.
Old Jan 18, 2009 | 12:29 PM
JK-KJ's Avatar
Well, I found it...it was the rear upper control arm bushing on the axle side of the arm. All I had was some silicone spray, so I squirted just a little in there and it stopped. Is it normal for the rubber bushings on these things to do this after a while, or should I be concerned?
Old Jan 18, 2009 | 01:00 PM
Mark Doiron's Avatar
Originally Posted by JK-KJ
... Is it normal for the rubber bushings on these things to do this after a while, or should I be concerned?
Mine (left, rear lower bushing) started doing that and I applied a little WD-40. Stopped immediately. Then started again in a couple weeks. I finally ending up pulling it apart and applying some grease to the bolt (it's not the bushing itself that's squeaking, it's the bolt/bushing mating surface). That was six months ago and I haven't heard it since. Of course, this squeak is so slight that the only time I hear it is running doors off, and I've been doors on for the last couple months. I don't think it's anything to be concerned about--as long as you have good bushings. There were problems a while back with these bushing literally falling apart. Mine haven't, but others (of a variety of shock mfg's) have.
Old Jan 18, 2009 | 01:28 PM
JK-KJ's Avatar
That's awesome, thanks alot...I'll be sure and just apply some grease and take care of it that way.
Old Jan 18, 2009 | 03:48 PM
Piginajeep's Avatar
no you shouldnt be concerned. But you should grease the bushings.
Old Jan 18, 2009 | 05:18 PM
whtIwrk4's Avatar
I had some noise at first from my Rough County shock bushing, and they deteriorated quickly. Rould country sent me new polyurethane bushings and admitted to having a bad batch. Good customer service, give them a call, they'll look after you.
