Rough country suggestions
it all depends on what you plan on doing, looks or wheeling? did you decide what wheel/tire combo that you're getting? i would get the RC 2.5 suspension with the 1.25 lift because I live in the city.
I agree also. 3.5 works great. Added the LCA drop brackets and a flipped drag link. Left off dropped pitman arm and drives better than stock. Mines a full time DD. will only see dirt roads and a few small trails.
The 3.5 is by far better bang for your buck. The 2.0's have a much better road ride than the 2.2's. Also adding control arm drops are a huge plus. Adding a little caster goes a long way with handling and the lower fram position gets the arms back to level which means better ride.
