Rough Country X-Flex Adjustable Control Arms
also very interested! i have the four inch RC lift on my 2dr rubicon. sure would like to fix the terrible ride and nurse along my stock driveshaft.. hard to beat 700$ for a complete set of adjustable arms
got my front lower x-flex arms in yesterday. they look like a good quality product but I dont have anything to compare them to.
the flex joints seem very smooth.
In the install instructions it says to mount the adjustable flex end to the frame. is this right? in the project jk write ups it instructs for the opposit. how should I install them?
Front/rear lowers are mounted with the flex joint on the axle. Rear uppers have a flex joint on both ends. Front uppers have a flex joint on the frame. All of these arms are adjustable so you can set your caster/pinion angles, no 2 JK's are alike.
Might also check out our new 4" x-series kit. Includes heavy duty adjustable upper and lower arms with rebuildable X-flex joints, adjustable front track-bar with heims joint, (4) ss brakelines, 2.2 performance shocks, springs, front discos, rear ext. links & rear trackbar bracket. For $1199
http://www.roughcountry.com/jeep_jk_4flex.html
- 60 day full refund satisfaction guarantee.
- Full Replacement warranty
- Ships same day - with 3 day or less delivery
