Rough Country X-Flex Adjustable Control Arms
Old Jan 6, 2010 | 12:12 PM
rcjeep's Avatar
Sponsoring Manufacturer
Originally Posted by racer83l
pretty cool. nice to see some more competition. I never heard of an X-flex joint.. is that just Rubber? And what is in the other end? Jonny? Heim? That photo above looks like johnny joints.
The X-flex joint is our version of a pivot joint, similar to a johnny joint.
Old Jan 6, 2010 | 03:59 PM
ssunde1's Avatar
i think im going to have to get some front lowers asap! does the x flex joint go on the axle end or frame end? definately going to be getting them, will have the fundage to do so later this month. very please with my RC coils. wish need the 2.2 shocks to go with it.
Old Jan 6, 2010 | 06:11 PM
gfe jeep's Avatar
Default Is There a
zerk fitting?
Old Jan 6, 2010 | 06:43 PM
superduperman86's Avatar
Originally Posted by gfe jeep
zerk fitting?
yes. one of mine came cross threaded but i just took it out and reinserted it straight.
Old Jan 8, 2010 | 04:34 AM
should I grease up the polyurethane bushings before I install? if so what all should I grease? just completely cover all the polyurethane?
there is a threaded hole on both joints. the flex joint came with zerks preinstalled, but the other end did not. should I get some zerks for that end as well?
I have been reading up on what grease people are using on poly bushings and it looks like synthetic marine grease works the best. can I use this grease on both of my joints? im not sure if the flex end has Poly bushings or not.
how often should I grease my bushings? every oil change?
Old Jan 8, 2010 | 09:26 AM
style_front's Avatar
How many degrees of articulation are these rated for? I think some one said that johny joints were rated for 30 degrees of articulation in another thread.
Old Jan 18, 2010 | 11:32 PM
Originally Posted by TeraFlex
Front/rear lowers are mounted with the flex joint on the axle. Rear uppers have a flex joint on both ends. Front uppers have a flex joint on the frame. All of these arms are adjustable so you can set your caster/pinion angles, no 2 JK's are alike.
Are you thinking about a long arm kit? I just looked under Rich's jeep (ohana trails) today and he had the heim at the body and a bushing at the axle for the lower control arms. He also had a bushing at the axle for his upper rear.....
Old Jan 25, 2010 | 04:51 AM
Originally Posted by NTXJK
Now thats one hell of a price
yes it is, i was lookin at doin the cheaper 4" rc lift, but after seeing this im definately goin the xtra for this, and the ride should be smoother also on-road
Old Jan 25, 2010 | 06:09 AM
toyfreak's Avatar
How much for the LCA's
I cant seem to find the price on the site for control arms only.
Old Jan 25, 2010 | 06:17 AM
hammerhead's Avatar
It's there $179.95
http://roughcountry.com/jeep_jk_xflex-control-arms.html
