rough ride skyjacker
Old Aug 29, 2011 | 09:28 AM
arasco85's Avatar
Default rough ride skyjacker
Installed 2.5 skyjacker coil and shocks. Only thing I don't like is how rough the ride is. Anyone running the skyjacker shocks? I'm just trying to figure out if its the shocks or springs.. any thoughts?
Old Aug 29, 2011 | 09:53 AM
wayoflife's Avatar
JK-Forum Founder
unfortunately, it's probably a little bit of both. assuming you installed the basic hydro shocks, replacing them with a good set of nitro shocks like OME's or bilsteins will help out a lot. also, make sure that you're not running too much air in your tires. iwth 35's, you should be at about 30 psi. too much air will give you a harsh ride.
Old Aug 29, 2011 | 10:16 AM
scotty6336's Avatar
Skycrapper IMO, I've had the lift on a different truck and it was poor quality.
Ill second that
Old Aug 29, 2011 | 12:31 PM
arasco85's Avatar
Thank WOL. I been checking out the 5100's. Guess ill pull the trigger on those and hope for the best. Everytime I take the Jeep in for a oil change the dummies crank my psi to 35. I bet they did it again, had load range e for a bit and they where back breakers at 35 lol
Old Aug 29, 2011 | 12:38 PM
JK08KATYTX's Avatar
I bought mine with skyjacker springs and shocks so I can't speak for that, but I can say when I just bumped my 315s down from 35psito 30 it made a huge difference. Maybe I'll look into new shocks, but then again its a jeep not a Cadillac so whatever
Old Aug 29, 2011 | 12:43 PM
sick jk's Avatar
When I bought my jeep it had the skyjacker 2.5" lift on it. I am still running it with the crappy shocks buy it does ride rough. My buddy has a terraflex lift and it is way smoother. I can't wait to get rid of the skyjacker lift and get terraflex. Terraflex also flexes way more. X2 on the tire pressure too!
Old Aug 29, 2011 | 12:45 PM
ejfernet's Avatar
Mine 2011 came from the dealer with 35's and the 2.5 Skyjacker lift. It was a very stiff ride. When the tires were at 30 or less it did help. I swapped mine out for a OME and much prefer the ride.
