Royal Purple Max ATF in Auto trans??
Old Oct 23, 2009 | 09:40 AM
JERSEYJK's Avatar
Default Royal Purple Max ATF in Auto trans??
Are there any problems using RP Max ATF in the auto 42RLE? I found some posts saying some people had problems not shifting properly after using RP. Thinking of using RP Max ATF in my auto trans and transfer case. I called RP and they say it's compatible with the ATF+4 Any input anyone?
Old Oct 23, 2009 | 09:42 AM
TeraFlex's Avatar
Sponsoring Manufacturer
I'm interested also in this or any other brand of synthetic trans fluid.
Old Oct 23, 2009 | 09:56 AM
ronjenx's Avatar
I wouldn't use anything that didn't say ATF+4 on the bottle.
There is no need to migrate away from what is supposed to be in there.
If RP is compatible with ATF+4, then why not put it on the bottle?
ATF+4 story:
h**p://www.allpar.com/mopar/transmissions/fluids.html
Licensed ATF+4® Brand Names
Advance Auto Parts ATF+4®
Carquest ATF+4®
Castrol ATF+4®
Chevron ATF+4®
Citgo Transgard ATF+4®
Coastal ATF+4®
Conklin ATF-Xtra Plus ATF+4®
Formula Shell ATF+4®
Great Wall ATF+4®
Havoline ATF+4®
MAG 1 ATF+4®
Mobil ATF+4®
Mobil Super ATF+4®
Mopar ATF+4®
MotoMaster ATF+4®
NAPA ATF+4®
Northland ATF+4®
O’Reilly ATF+4®
Parts Master ATF+4®
Parts Plus ATF+4®
Pennzoil ATF+4®
Petro-Canada ATF+4®
Quaker State ATF+4®
Ravenol ATF+4®
Sinopec ATF+4®
Super Tech ATF+4®
Texamatic DC ATF+4®
Ultramax ATF+4®
Valvoline ATF+4®
Old Oct 23, 2009 | 04:06 PM
Flash1034's Avatar
Great link. Thanks for the info.
Flash
Old Oct 23, 2009 | 08:49 PM
JERSEYJK's Avatar
So nobody used Royal Purple Max ATF in their auto trans successfully?
Old Oct 23, 2009 | 09:30 PM
ronjenx's Avatar
If someone posted they used it successfully, would you consider using it?
Old Oct 23, 2009 | 09:51 PM
joe002's Avatar
As already indicated, Mopar ATF+4 is already synthetic and, warrantee wise, a “perfect” oil for your transmission.
Here’s a link where the Dealer thought Royal Purple was used in a tyranny that puked. Do you want to go through that hassle?
I was at the Dealer today and picked some up for $5.35 a quart.
Old Oct 24, 2009 | 01:28 AM
JERSEYJK's Avatar
Ok, thanks guys. Mopar ATF+4 it is! Thanks.
Old Oct 24, 2009 | 05:59 AM
duneslider's Avatar
Mopar ATF+4 is synthetic and is supplied by valvoline and is the same as valvoline atf+4 which is synthetic. Why spend more for the RP? I replaced my tranny fluid at 38k and it still looked good.
Old Oct 24, 2009 | 06:17 AM
ronjenx's Avatar
Yes.
See post 3 above for a complete list of licensed and tested brands.
