RR 8500 winch stuck
Hey guys, my Rugged Ridge 8500 winch clutch is stuck in freespool. Anyone have this issue and been able to fix it? I've sprayed the be-jesus out of it and am letting it sit. Just glad this didn't happen in the woods
I have the same winch and had the same problem. I removed that tiny rubber plug and put a few drops of 3 in 1 oil and moved the lever back and forth while I pulled line out. That did the trick. You should monthly move the lever back and forth for maintenance.
Mines been great since. It works hard at pulling.
