Rubbing Question
I have a 2010, 2 door with a 2.5" lift.
I am looking at some 285/65/18's ( Nitto Trail Grappler )and i beleive they will rub since they are wider than stock.
How much will they rub, is it just at the extremes? Can i drive around town untill my spacers show up?
I want to get the tires this weekend, but wheel spacers are taking a while to deliver.
Stock 18" Wheels FYI
Thanks
Thanks
You might want to price out 16" tires with new wheels with a 4.5" back spacing, it might be cheaper then buying 18" tires and a set of spacers.
And to answer you questions they will rub but not too bad, if just driving around on the road you should be fine. Running off road disconnected at full flex you will rub the fenders if you have the factory bump stops.
