Rubi electro disco Aftermarket replacements
Old Apr 26, 2012 | 08:06 PM
jpsopris's Avatar
Default Rubi electro disco Aftermarket replacements
Hello everyone newbie here with a question that has probably been beet to death but here it goes.
I busted a sway bar link over the weekend in Moab, luckily a local jeep rental shop had one on hand and he explained that it was a common issue and that he just rips them out in his rental fleet because he's tired of replacing them all the time.
I'm on an 08 Rubi with a 2.5 old man lift and 35" tires.
I replaced the electronic disco 2 times under warranty and told myself if it was to happen again I would replace them with aftermarket sway bar and disconnects.
So here are a couple of questions I hope to shed some lite on
What are some brands that people suggest for a budget around $1000.00?
Do/should I replace the rear sway bar?
Is there any extra parts that I'll need to install other then the kit?
I thank you all in advance for all your help
Old Apr 26, 2012 | 08:26 PM
txjeeplover's Avatar
Evo has a kit under $100 to convert the Rubicon electronic disconnect system to a manual system. If yours fails again, purchase the Evo kit and your choice of end links. BUT I think that you have end links that are too short or too long for your application.
https://www.jk-forum.com/forums/modi...onnect-181289/
Old Apr 26, 2012 | 08:38 PM
Nwapache's Avatar
X2 on this ^^^
Old Apr 26, 2012 | 09:26 PM
BKGM Jeepers's Avatar
ORO sway-loc dual rate. Northridge can get you one for under 1000. And you simply flip a switch between on and off road. It won't break.
Old Apr 27, 2012 | 09:22 AM
jpsopris's Avatar
Thank you all for the suggestions, any thoughts on the teraflex s/t duel ?
