Rubi front/Non Rubi rear differentials
Old Feb 9, 2021 | 12:00 PM
Rich Hanner's Avatar
Vet Army
Default Rubi front/Non Rubi rear differentials
I'm going to be re-gearing my Jeep soon. It's got a non-rubi rear differential and a D44/J8 rubi front differential. I know the differences on axle splines and all that, but I'm wondering specifically about the non-rubi rear ring and pinion. Are those the same? In other words, can I buy a complete set of Rubicon gears with the master install kit and expect the rear ring & pinion and bearings to work with the D44HD that's in the back, instead of ordering all the parts piecemeal?
Old Feb 10, 2021 | 05:29 AM
OscarMlke's Avatar
Not sure what you're asking here, but the rear diff on a stock unlimited sport (like ours) should be a D44. If you're going to remove the front D30 and replace it with a D44 then the only issue I see is with the transfer case as it's not a Rubicon transfer case. others wise upgrading your gear ratio in both the front and back to the same gear ration should be acceptable.
Old Feb 10, 2021 | 06:00 AM
Vet Army
It's no so much the ratio, I'm mostly wondering what the difference is between the rear ring and pinion if it's labeled "Rubicon" or "Non Rubicon". I know the splines are different, I'm just curious about the ring & pinion itself.
Old Feb 10, 2021 | 06:10 AM
resharp001's Avatar
Loved
Community Favorite
I'm 99% sure that based on the retail websites, the rear R&P and master install kit is going to be the same for a non-rubi D44 rear as a rubi 44. I say that cuz the listings note the same part for Sport, Sahara, and Rubicon. I don't order and install gears every day so I'm not going to say that is 100% accurate, but I think you are correct in your thinking that you can order 1 complete set of gears for front/rear rather than ordering separate. I'd maybe lob a question into the guys at Northridge or your retailer of choice.
IE - if you just look at the rear R&P set and look at fitment, the same rear R&P shows fitting all the rear 44 models.
Old Feb 10, 2021 | 10:29 AM
nthinuf's Avatar
The gears that went in my non-rubicon rear 44 had 'Rubicon' stamped on the box.
Old Feb 10, 2021 | 10:36 AM
resharp001's Avatar
Loved
Community Favorite
You're getting Rubicon performance!
Old Feb 11, 2021 | 05:53 AM
scubatech's Avatar
I've set up a couple of these a few years back and the only difference I saw was the Rubicon axles are different lengths. So the carrier must be different for the offset to be correct. When I put a Pro Rock in the front I went conventional so I wasn't restricted to just the Rubi or Air Locker options. As stated the R & P is the same.
Old Feb 11, 2021 | 11:30 AM
Digger 5's Avatar
The gears are the same between a sport rear and a Rubicon.rear. Pinion bearings are the same too. Diff carrier bearings are different.
Old Feb 12, 2021 | 11:43 PM
2011oscarmike's Avatar
What exactly does the T-Case have to do with this? As far as I know you can run Rubi T-case on D30 44 60 80 the same as you can run a non-Rubi t-case on the same axles. Sorry OP I can't help you with an answer and neither can this guy.
Old Feb 13, 2021 | 04:43 AM
scubatech's Avatar
You can run either "T" case. The ratio is the difference with the Rubi case being 4.1 to 1. The Rubi case has a planetary gear set which allows the lower reduction. The Sport case is 2.7 to1 if I remember correctly.
