rubi swaybar HEEELLLLPPPP
Old May 7, 2011 | 10:29 PM
srt8ftw's Avatar
Default rubi swaybar HEEELLLLPPPP
hey everyone, this might be a dumb question but when i am driving and i hit the sway bar disconnect i really cant notice anything. i will try and turn hard and i feel nothing diffrent. sumtimes when it is on the light blinks and sumtimes it is soild, what does that mean? i tried to get on a rock to flex and i got it flexing good and then i decided to try the same thing with the swaybars connected and i seemed to fully flex all the same. am i doing sumthing wrong?
Old May 7, 2011 | 10:35 PM
jtjk's Avatar
the sway bar is only disconnected when the light is solid. in order to disconnect it you need to be on level ground. the light will flash, you may hear a click and then the light will become solid. you can only drive under 15 mp or something like that with the sway bar disconnected. if you exceed this speed it will start to flash and reconnect as soon as you are on level ground again .
for more info check your manual.
Old May 7, 2011 | 10:38 PM
ronjenx's Avatar
What do you mean by "When I'm driving"?
It won't disconnect in 2wd, or above 18 mph in 4wd high and low.
Once disconnected, sometimes it takes a while to reconnect. The sway bar halves must be lined up for it to connect. It's all in the owner's manual. You can download one from the Jeep web site if you don't have one.
Old May 7, 2011 | 10:48 PM
Red Dog's Avatar
It sounds like you are doing everything correctly. You just are not driving it in a place that you can feel it. It makes a big difference in the rocks or on choppy roads. If there is an articulation ramp that you can use, you should try it attached and un-attached. You will see a difference.
Old May 7, 2011 | 10:53 PM
srt8ftw's Avatar
ok so i have to be on level ground, under 15mph and in 4hi or low. ok ill try it out. is it only helpful for rocks? what other scenarios would disconnecting the sway bars be good? my jeep was still flexing GOOD without disconnecting them. front wheel was almost off the ground and the back wheel was completly tucked in as far as it would go.
Old May 8, 2011 | 04:34 AM
SLVR07's Avatar
If you get it flexed up too much and it is not disconnected you may break the small tab(s) off the front axle housing. You want to use it when you are going over rocks.....the idea is to have all the tires on the ground.
