rubicon 44
Old Jan 29, 2012 | 04:35 AM
DMB1685's Avatar
Default rubicon 44
hey guys, not sure why but im having trouble with the search today and its not working soo i hate to do this because i know my answer is on here already. but here we go, i have a 09 unlimited X, and i want to upgrade my front dana 30 to a 44. i want to have lockers aswell soo, what does it take to put the rubicon front and rear dana 44s in my X model? and is there any kind of wiring in the jeeps harness for the switch in the cab for the lockers? any input would help.
Old Jan 29, 2012 | 04:51 AM
Bigb's Avatar
I'm not sure if the wiring and relays are there or not, but I would look into wiring the lockers separate from the JK's computer. So that you can switch them on when ever you want, not just in 4lo.
Old Jan 29, 2012 | 04:57 AM
blockrockin's Avatar
it is a easy bolt in... just pull out the dana 30 and bolt up the dana 44... then just run 12volts to the lockers with a switch and your good to go ! top plug... their is a bottom sensor plug that tells you if your lockers are engaged or not.. but you dont have to hook that up . good luck
Old Jan 29, 2012 | 05:09 AM
DMB1685's Avatar
ok sounds pretty damn simple then, i just remember hearing rumors you cant do it. i was always woundering why that was and thought maybe a little welding had to be done... but this sounds good. cant wait to start
Old Jan 29, 2012 | 05:15 AM
yeah its not hard at all you shouldnt have any issues... plus this was you can turn your lockers on any time you want
Old Jan 29, 2012 | 05:44 AM
wayoflife's Avatar
JK-Forum Founder
as mentioned, it's a simple bolt up installation and, there is a wiring kit that you can buy to complete the install if you want it to be completely factory.
Old Jan 29, 2012 | 08:30 AM
ChopN's Avatar
I think I saw complete rubi 44 fronts for sale on quadratec. Just over $3,000.
Old Jan 29, 2012 | 08:54 AM
pcmasten's Avatar
Veteran: Marine Corp
I changed out the d30 in my Sahara w/ a Rubicon D44 without problem. There's a writeup on how to wire the elocker (using a relay) if you use a Rubicon axle. I stayed with the stock D44 rear axle, installing an ARB locker in it and new axle shafts. It's a good time to re-gear if you are going to run larger tires.
Old Jan 29, 2012 | 09:21 AM
DMB1685's Avatar
Ok cool, In running 37's now with 5.13 gearing. I'm changing to 44's so I'm not worrying all the time plus thinking about getting 40's from a friend.
