Rubicon acle swap
Old Dec 21, 2014 | 11:46 PM
m_cromer's Avatar
Hello everyone! I'm fairly new to the Jeep world and was wondering what all I am going to need to do for a Rubicon axle swap. I'm getting both axles from a friend of mine that is upgrading the axles on his Rubicon soon. I've found the wiring harness and switch module online, but is there anything else that I am going to need? Thanks
Old Dec 22, 2014 | 12:06 AM
JK505's Avatar
I'm about to do this too. Look up the threads on how to wire the lockers. You'll need the switches, obviously, but besides that, if you have some pretty basic hand tools, you're good to go.
Old Dec 22, 2014 | 03:29 AM
Invest2m4's Avatar
Yep, easy stuff. A few more steps than installing a lift.
You should ask your friend to just cut the ends of his harness for you. You just want the connectors and enough wire to splice. Then you don't have to buy a $100 harness for nothing.
Switches depend on how you want them to work. Personal preference.
Whatever you do, don't attempt to set it up like a factory rubicon and run through the computer. Terrible idea.
Old Dec 22, 2014 | 06:58 AM
Maertz's Avatar
This^^^^. When I had that setup I could not stand it, I tapped into the relays and ran a toggle switch on them to be able to engage them whenever i wanted.
Old Dec 22, 2014 | 07:05 AM
sea bass's Avatar
Did you have to disable traction control to do this? I hate how the rubi-lockers work - I'd love them on my spod
Old Dec 22, 2014 | 07:27 AM
m_cromer's Avatar
Thanks guys. I was wondering how I was going to manage the whole computer aspect of it, but now that I know, I feel much more comfortable. Just out of curiosity, are the computers different between the two? His is a 14 and mine is an 08
Old Dec 22, 2014 | 07:39 AM
Maertz's Avatar
no you do not, you just splice into the relay wires and run them each to a switch. Ive seen a few write ups around. Hardest part was getting at the short wires on the relay...
Old Dec 22, 2014 | 09:41 AM
Invest2m4's Avatar
Avoid the computer all together. You just need a 12v power source.
