Rubicon E-lockers
Im doing a gear change in a couple days and was wondering if anyone knows how to disconnect the electrical wire on the Rubicons E-locker. I've been looking and I cant seem to find any info on it.
if you mean internal wire from e-locker - follow the wire from ring to diff case, there is connection inside (parallel to ouside), it is easier to disconnect after removing clamp holding bearing (passenger side), it is a bit tight but doable,
I did gear change couple weeks ago,
this can be helpfull: https://www.me.com/gallery/#100111
oops, I gave you wrong link,
here is the correct one:
http://gallery.me.com/mituk#100111
and it is set of pictures with descriptions from my gear change,
I thought you may look as you prepare for your gears change
and it is seto of picture with some ddescriprins from my gear change,
