Rubicon Express 5.5 inch long arm
Old Aug 23, 2015 | 05:32 PM
Wild1s's Avatar
Default Rubicon Express 5.5 inch long arm
Is anyone running this kit? How do you like it and have you had any problems??
I just put one on my 2015 4 door Hard Rock edition
I'm running super swamper m16 37x13.5x17 for now but going to change to
toyo mt in the same size
i had it in to 4 wheel parts and they set up the front end but the steering just doesn't feel right
any feedback??
thanks
Old Aug 23, 2015 | 07:09 PM
nthinuf's Avatar
Describe the steering feel. Which specific components were installed? Post the alignment specs. What psi are you running in the tires?
Old Aug 23, 2015 | 08:05 PM
Wild1s's Avatar
rubicon express 4 link long arm 5.5"
fox 2.0 remote res shocks
fox steering damper
30 psi
4.4 degrees positive caster
almost feels like a lot of bump steer
just a lot of feed back in the steering
Old Aug 23, 2015 | 08:26 PM
Albino Lizard's Avatar
Originally Posted by Wild1s
rubicon express 4 link long arm 5.5" fox 2.0 remote res shocks fox steering damper 30 psi 4.4 degrees positive caster almost feels like a lot of bump steer just a lot of feed back in the steering
Reduce your tire pressure to 25 ish. Make sure your steering stabilizer doesn't have any dead spots. Check your ball joints. I ended up replacing mine all the bump steer problems are gone.
Old Aug 24, 2015 | 06:24 AM
Invest2m4's Avatar
Is your drag link flipped? With that much lift, you will have a ton of bump steer given the angle on the drag link and track bar. Really, anything over 3.5" requires a drag link flip and track bar relocation.
Old Aug 24, 2015 | 08:34 AM
Wild1s's Avatar
Yes drag link is flipped as well as drop bracket and adjustable track bar
Old Aug 24, 2015 | 09:03 AM
WarPig512's Avatar
Definitely drop the psi, as already mentioned. I noticed a huge difference just dropping the 3-4 pounds.
Old Aug 24, 2015 | 09:06 AM
Wild1s's Avatar
My jeep only has 3k miles on it, I don't think the ball joints are bad
I'll try the tire psi and see how that works
thank you
Old Aug 24, 2015 | 09:10 AM
FlexyJK's Avatar
Can you post a pick of your front end set up? I have seen some set up weirdly.
Old Aug 24, 2015 | 09:53 AM
Maertz's Avatar
Chalk test it, don't just wing psi based off what you read...hate to see you eat tires up.
