Rubicon Express BB?
Old May 5, 2008 | 10:54 PM
JK Dawg's Avatar
Default Rubicon Express BB?
Anyone have experience with the Rubicon Express 2.5 front & 1-3/4 rear lift? I am leaning towards that one at the moment. Your thoughts?
Old May 6, 2008 | 06:02 AM
Cliff2004t's Avatar
I have an 08 2-door and had the RE spacer lift installed. It rides better than stock, nice and firm with no mushy feel. I like the Bilstein shocks it came with.
It also sits perfectly level, no more rake. 33x12.5x16 tires fit good.
Old May 6, 2008 | 07:12 AM
bim6180's Avatar
I have the same kit with the monotube shocks (BTW, the shocks are by edelbrook, not bilstein). Still liking them...perfect if you just need some mild lift and fit 33" to clear at full flex
Old May 6, 2008 | 07:14 AM
RevyJKU08's Avatar
Same Kit with monotube shocks.....looks great with 33's and ride is better than stock.
Old May 6, 2008 | 10:08 AM
JK Dawg's Avatar
Thanks, I'll probably go with this the RE, especially since the shop said the electric sway bar disconnect will still work.
Old May 6, 2008 | 10:30 AM
Mauibuilt's Avatar
I just installed this lift on saturday. I got the kit with the monotube shocks.
The ride is great. the flex is great but the install was a little frustrating.
The monotube shocks require some mild modification. And if it catches you by surprise like it did me without the right tools, its going to take longer to install.
First, for the front shocks you have to remove a bar/pin from the new bushings and remove and install the sleeve from the old bushings from the old shocks.
For the rear shock you have to drill out the holes on the mounting post so the original bolts can go through them.
Here is a pic http://project-jk.com/wp-gallery2.php?g2_itemId=72841
Old May 6, 2008 | 12:33 PM
bim6180's Avatar
You don't really need to drill out the holes for the rear shocks.. just replace them with the stock ones.... although...that was real pain to do if you don't have a bench vise. But, if you have a bench vise and grease, it shouldn't be that hard to do
Old May 6, 2008 | 06:31 PM
Mauibuilt's Avatar
I know. I wish I did the job at my grandpas house since he has a nice big bench vice. I used this little dinky one I had laying around along with grease and a good mallet. still a pita.
