Rubicon express lift question
Old Sep 20, 2014 | 05:57 PM
holmes4x4's Avatar
Default Rubicon express lift question
Just purchased a 3.5" rubicon express lift and purchased the rear track bar separately. Do I still need to use the rear trackbar relocation bracket if I'm using the new adjustable trackbar?
Old Sep 20, 2014 | 06:24 PM
08leocon's Avatar
Not if it adjustable
Old Sep 20, 2014 | 06:34 PM
nthinuf's Avatar
Some relo brackets also raise the trackbar to fix the rollcenter which was affected by the lift. I am not familiar with RE's bracket, does it just center the axle, or does it raise the trackbar also.
Old Sep 21, 2014 | 06:48 AM
TheDirtman's Avatar
For more ideal geometry and better ride quality, yes you should install a raised track bar bracket. You just want to make sure that if you use the adjustable track bar it can be adjusted to factory length.
Old Sep 21, 2014 | 06:36 PM
holmes4x4's Avatar
Thanks just got the lift in will have updates soon
