Rubicon locker mod
Old Feb 19, 2013 | 11:11 AM
Texas Crawler's Avatar
Default Rubicon locker mod
Hello, new to JK-forum. I want to use factory Rubicon lockers on my JK Sport, I have the Rubi take off axels, what parts do I need off of the Rubicon to make the lockers work?
Old Feb 19, 2013 | 11:33 AM
v8zracer260z's Avatar
Veteran: Marine Corp
You can do this two ways first get the oem harness for the axles and the dash switch and have Jeep program them to work. This set up would also allow you to run the rubi sway bar too. The other way is to wire the lockers to relays and install an aftermarket switch to control them
Old Feb 19, 2013 | 11:36 AM
Also what year is your jeep if it's an 07-10 the oem route will work on 2011 and up it will work for the sway bar and help wire the axles but you will need your own relays and switches
Old Feb 19, 2013 | 03:49 PM
shag7265's Avatar
His jeep is 2010, the axle is from a 2012 JKUR.
