Rubicon Locker Mod Question
Old Mar 19, 2011 | 05:08 PM
jpthunder's Avatar
Default Rubicon Locker Mod Question
So, I've been searching and reading rubicon locker mod threads for a while now and it's obviously desirable to use your lockers in 4hi or even 2hi. My question is, can you alter the stock relay or harness to somehow just actuate the lockers in all gear ranges with the stock switch? I don't really want aftermarket locker switches in addition to the stock one, and I've never needed to lock the front only. Can I just cross some wires or ground a wire or something? I don't care if the lights blink as long as the lockers are engaged. Sorry if this is posted somewhere else.
Old Mar 19, 2011 | 06:24 PM
RLW007's Avatar
I understand that the superchips flashpac will let you use the lockers in 4 Hi.
Old Mar 19, 2011 | 06:35 PM
EN2DIRT's Avatar
That is correct. Although I haven't done it yet.
Old Mar 20, 2011 | 04:51 AM
jfbullseye's Avatar
Yes it will but only one of them . Its either the front or the back . Cant do both at the same time .
Old Mar 20, 2011 | 04:59 AM
tommyluv78's Avatar
https://www.jk-forum.com/forums/show...ght=locker+mod
this is the write up you're looking for. it tells you how you can be able to use your lockers any time you want.
Old Mar 20, 2011 | 05:44 AM
tommyluv78's Avatar
Originally Posted by TheDirtman
Before responding you guys should really read the op. He wants to use the factory switch and not install something else.
thats what the write up i posted the link to will tell you how to do.
Old Mar 20, 2011 | 05:58 AM
tommyluv78's Avatar
my bad............
Old Mar 20, 2011 | 07:18 AM
Hovo's Avatar
i was wondering if the lockers use some sort of relays as well.. now i know its all computer controlled. It wouuld be nifty to have complete control of the lockers in all gears.
Old Mar 20, 2011 | 07:25 AM
jpthunder's Avatar
So when you do the mod with the switches are you completely bypassing the stock switch or do you still have to activate the stock one before the installed switches will work?
Old Mar 20, 2011 | 07:48 AM
knotaddicted's Avatar
The factory switch still works like it always did. only in 4low. The aftermarket switches will turn on the lockers, but the display in the dash blinks because the computer thinks there is something wrong, like the lockers should not be engaged, but they are.
The factory switch does not have to be turned on for the aftermarket switch to work.
