Rubicon springs under a jk
Old Mar 18, 2014 | 10:06 AM
taylorfain2009's Avatar
Default Rubicon springs under a jk
Ok jeep peeps. My friend is selling me her rubi springs out of her 4 door rubicon. I am going to put them under my 2 door jk which has a 2 inch budget boost as it is. So that should bring me up to about 3 or 3.5 inches. Should I also install her shocks off the four door under my jk? Or would that not work? Good idea? Bad idea?
Old Mar 18, 2014 | 10:19 AM
Joe_B's Avatar
You need check what coils you have and what coils she has. If she has heavy duty coils and you have light duty coils then you'll see a bit of height from the swap. Her stock shocks will be too short for the amount of lift you may get (rubi coils + BB). Also with the 2 door you may need to start looking at other suspension upgrades and maybe a new driveshaft at 3"+ of lift. Search the forum or just use google and all the info is out there in several others threads like this one.
Old Mar 18, 2014 | 01:19 PM
olyelr's Avatar
Yes, you must check the spring numbers. Just cause it is a rubi doesn't mean they are heavier springs that will offer lift (although coming off a 4 door and going on a 2 door, chances are they are stiffer spring rate then yours). Still, don't expect much lift.
Old Mar 18, 2014 | 02:32 PM
Thanks for the info. Really appreciate it. I'm going to go ahead with the springs but wait for the shocks and do more research.
