Rubicon Sway bar e-disco
Old Oct 19, 2010 | 09:26 AM
reechee's Avatar
Default Rubicon Sway bar e-disco
I have an 07 2dr rubi, and I'm starting to plan out a lift to save up for when the time comes for new tires. What do I need to be aware of regarding the stock disconnects and installing a lift kit? I don't want to lose the functionality of the e-disco, right?
Old Oct 19, 2010 | 09:37 AM
Bypass's Avatar
You just use longer links.
Old Oct 19, 2010 | 10:03 AM
sm_rubi's Avatar
x2
We have around 4" of lift and are running the Off Road Evolution Sway Bar end links and our e-disco works great...never a problem!
Old Oct 19, 2010 | 10:26 AM
nthinuf's Avatar
Yep, you want them long enough to keep the swaybar level, or slightly positive.
When flexed, having short links can cause the swaybar to flip around backwards, which turns the links into pretzels. Quite a few good pics of this if you look around a bit...
