Ruby E-Discos
Old Jul 10, 2008 | 06:57 PM
P Nasty's Avatar
Default Ruby E-Discos
Ok so im getting a Stock rubicon electric disconnect for my sahara...It came off of a ruby with 6k miles on it and hasent been used since... The only problem is it dosent have the wiring harness...is it possible to buy the wiring separate from any web site? or will i have to rigg it up or something?
i want it to be done riht and have the stock switch put in where it should be...is this gonna be possible? Also... im getting it at only a couple hundred more than just getting JKs discos... Do the ruby E-discos show their worth? I mean are they pretty strong? i dont wanna get it all put on and hooked up and then have to worry about it dying in a week :P Any input would be great... Thanks so much
-Zack
Old Jul 10, 2008 | 07:05 PM
eDiveBuddy's Avatar
They sell the harness and switches at quadratec
Old Jul 10, 2008 | 07:07 PM
Piginajeep's Avatar
4wd sells the harness and switch, I have the installation instructions if you need it
Old Jul 10, 2008 | 07:15 PM
eDiveBuddy's Avatar
I'll take a copy of the instructions please, please
Old Jul 10, 2008 | 07:17 PM
Piginajeep's Avatar
if you have a fax number send me a PM. These are on paper. I really need to do a write up
Old Jul 10, 2008 | 07:28 PM
P Nasty's Avatar
lol yeah i was just looking through the 4wd magazine and found them the problem is its a whole new switch box and its like 119 bux... is it not possible just to get the 1 switch and add it to my already owned box? seems like that would be alot easier and cheaper...but i guess ill have to do what i gotta do...
Old Jul 10, 2008 | 07:33 PM
Piginajeep's Avatar
No, the switch box is actually a circuit. Sorry..
I'm buying a harness for my front axle, I dont need the Sway bar hook up. I just need the plug ends for the axle. I'll chop the e-disco harness end off for $50
Old Jul 10, 2008 | 07:42 PM
eDiveBuddy's Avatar
Wow, that more than I paid for the switch and harness from quadratec
Switch $40 http://www.quadratec.com/products/52446_110.htm mine does not have the axle lock and it cost 5 buck less. Harness was $70
http://www.quadratec.com/products/52446_111.htm
Old Jul 10, 2008 | 07:44 PM
Piginajeep's Avatar
the picture is not the correct one, While I'm sure the product is, The picture is not. I'll work on a write up tommorrow
EDive the fax is going out now
Old Jul 10, 2008 | 07:51 PM
eDiveBuddy's Avatar
Thanks agaian Sir! I found the switch. It's $30
http://www.quadratec.com/products/52446_114.htm
