Rugged Ridge Front Skid Plate issue
Hi all,
So I installed a RR XHD bumper without issue on my 2011 Sahara this weekend. Got the RR front skid plate as well. I must have gotten an earlier version, as I has to use a grinder on the front cross member to get it even close to fitting. However, the rearholes still don't come close to lining up on the bracket.. My options are: 1) Only use front bracket holes as well as the lower holes drilled directly into the cross member for two secure points. 2) Elongate the rear holes so they line up with the holes. Using the supplied washers, I don't have a lot of concerns on this method. 3) Try to grind down the cross member even further. I'm loathe to do this for strength purposes. Thoughts? I like the looks of this skid plate as opposed to the full sizse ones. |
I'll be right there with you next week. I just bought the RR bumper and skid plate for my 2010.
My 2010 did not ahve the holes through the cross member so i did nto bolt it there. Only used the brackets under the sway bar and the side bolts. It was more than sturdy
Ruugged Ridge Products
Originally Posted by mattgt5
(Post 2583832)
