Rugged ridge side armor clanging?
Has anyone else had this problem. I have them on my o7 rubi with the rubi rails still on. I called tech for rr and they said they would get back with me...... that was two weeks ago. Just wondering if anyone found an easy fix.
I had the same issue. I put a small piece of rubber between the side rail and the rubicon rail. Once I snugged up the bolts it holds the rubber in place and no more rattle.
I actually cut up this -Attachment 16394
The tool (Craftsman) is from sears the loop is made from thick rubber it is about 1/4 inch thick. You could use is it remove your oil filter. I have used it for turning plastic plumbing parts under my kitchen sink.
I think it is hitting the rubi rails it is a very small gap that is between them. I have tryed to make it make the sound myself but no luck. Once you get on the road and hit a sharp bump there it is though. I will try the pieces of rubber and see if that works
