Running air for MTRs
Old Apr 4, 2013 | 09:15 AM
mattyhfd's Avatar
Default Running air for MTRs
what do you guys run the air pres in your MTRs at? i have 35x12.5 R15 MTRs, about 10g on them, and i feel like they are wearing a lot faster then they should be.... I run them at 29 on the road
Old Apr 4, 2013 | 09:19 AM
JLsJK's Avatar
I run mine at 28 and feel like they could be a bit lower to really get all the tread on the pavement. I'm thinking 26 would be best for tread wear on my light 2 door.
Old Apr 4, 2013 | 11:27 AM
bryz_rubi's Avatar
That's sounds a little low for on the street. It might be the reason they are wearing faster.
Are the edges more worn than the center?
I have 37x12.5x17 MTRs and I run them at 35 on the street. Even wear pattern, edge to edge and also I rotate every 3k miles.
You might even see a slight improvement in gas mileage.
Old Apr 4, 2013 | 03:15 PM
12HTownSahara's Avatar
I'm running 26lbs in my 37 inch mTrs. Turned out great with the chalk test. Wearing fine.
Old Apr 5, 2013 | 08:39 AM
St1g 32's Avatar
I have MTR as well. LT285/70R17 or 33/11.5. They are smaller than yours but I run 32 PSI. Felt the ride was the best at this PSI. I have 18K miles on them, mostly on road. I would say they have a good 5K more miles till they are shot.
Old Apr 5, 2013 | 08:50 AM
Nibsirb's Avatar
I'm running mine around 29-30 if I'm not mistaken. Only had them for about 1k miles or so, seem to be doing pretty well though
Old Apr 5, 2013 | 02:14 PM
spedly's Avatar
26psi on a light 2-door. They have about 40% tread left after 20,000 miles, but they are starting to get hard and not work very well off-road.
Old Apr 5, 2013 | 03:04 PM
bryz_rubi's Avatar
You guys have me thinking I'm running to high pressure.
Old Apr 5, 2013 | 05:03 PM
Mgimelli's Avatar
Ran 26-28 psi in mine and were great
Old Apr 5, 2013 | 05:04 PM
k0260's Avatar
I run 30-32 in my Hankook Dynapro Mt's.
