running lean. ????
Old Jun 10, 2012 | 06:27 AM
jaybrown's Avatar
How can you tell if your running lean. I don't want to wreck my engine. When I run 87 tune compared to 93 tune. The 93 tune is way louder and more of a popping sound when I let off the gas. When you run lean does that mean the octane isn't high enough?
Old Jun 10, 2012 | 08:10 AM
jaybrown's Avatar
Anybody know how u can test this?
Old Jun 10, 2012 | 08:26 AM
08RescueGreen's Avatar
Vet Army
Running lean means your fuel:air ratio is off with the fuel ratio being too high. That will cause the popping sound you are hearing. Have the person who tuned your jeep check it out and change the ratio. Switch to the lower octane tune to preserve engine longevity.
Old Jun 10, 2012 | 08:27 AM
Dark Shadow's Avatar
Only way to. Check if your running lean is to buy a wide band o2 sensor gauge
Or go find a dyno and do a couple of runs on it. They will tell u.
The jk's are tinned for mid grade. Running anything else can hurt or cause problems.
Old Jun 10, 2012 | 01:33 PM
jaybrown's Avatar
Ok thanks I'll stick to 87 tune not 93.
Old Jun 12, 2012 | 01:02 PM
jaybrown's Avatar
I think running lean is the air ratio is too high not enough fuel. ????? So higher octane would help ???
Old Jun 12, 2012 | 01:12 PM
evoviii2jk's Avatar
Running lean does mean that you don't have enough fuel. Your air ratio is too high. Higher octane fuel won't help enough. If you are truly running lean you need to get it fixed. Running lean makes cylinder temps rise and if they get hot enough you can melt pistons. Not that you will reach that kind of temps in a jeep.
Old Jun 12, 2012 | 05:36 PM
jaybrown's Avatar
Ok thanks. So if I run the superchips 93 tune on my jeep. Why do some people say I'm going to run lean. It has more power so isn't it spraying more fuel
Old Jun 12, 2012 | 06:24 PM
evoviii2jk's Avatar
You want to dance that fine line for more power. Leaning out a factory tune WILL give you more power but not knowing what your AFR's are reading you run a significant risk. Coming from the import world we would always have cars tuned and dynoed
Old Jun 12, 2012 | 06:27 PM
jaybrown's Avatar
The dyno will show you that ?
