Rust proofing your underside
Old Jun 19, 2011 | 08:25 AM
AV8RS3V3RN's Avatar
Default Rust proofing your underside
So I've been debating on what to get/have done on my Jeep regarding rustproofing. I want to Line-X the tub, but can that be used on the underside and actually be worth while? Heck should I even worry about RP'ing the underside? I plan on lifting and doing quite a few mods in the next 3 years, will any RP'ing affect changing out parts?
Hopefully this isn't too much of a NOOB question.
Old Jun 19, 2011 | 08:36 AM
Croce's Avatar
I like to use rustoleum undercoating. Its a rubberized spray
I just sprayed down the frame and the under the tub for when i lived in New england with all the salt and snow
I also just used normal spray paint for the Muffler and Axles (use BBQ or hi heat for the muffler)
Old Jun 19, 2011 | 09:57 AM
teamgreen666's Avatar
Im looking at getting this little hockey puck looking thing. Take a look at it ggod luck with that...
www.defender-plus.com
Old Jun 19, 2011 | 10:02 AM
Joisey's Avatar
I spot spray w/ rustoleum. It keeps it down, and i figure in 10 years ill have a 1/4'' layer of spray paint on my frame
Old Jun 19, 2011 | 10:22 AM
AV8RS3V3RN's Avatar
Interesting device...but I'm not sold on it. Sure it slows it, but it only will have effect on parts that are connected "metal to metal". Won't go around/thru rubber, plastic, etc. Plus it only slows the rusting process. Let us know how it works for you though.
POR-15 looks pretty good. Do you all recommend personally applying or have a "professional" do it?
Old Jun 19, 2011 | 12:07 PM
Noxian's Avatar
A rust paint as mentioned above is the best bet, wont hold in moisture and cause it to rust faster.
I see very little point in it though since its just going to get scrapped off anyway offroad, and chances it will rust in a area where you cant paint anyway, same place water etc collects as it is.
Old Jun 19, 2011 | 02:07 PM
wmphoto's Avatar
I at least twice a year go under and spray liberaly with Rustoliem... I've done this now with three trucks and two jeeps... Keeps the rust off and/or at bay...
Old Jun 19, 2011 | 02:15 PM
moalder's Avatar
I know next to nothing about the underside of my Jeep but I can tell you that parts of it are pretty rusty under there - other parts are perfectly fine. I bought some Rustoleum Rust Reformer, my question is, is there anything under there that I shouldn't spray and if so how do I know what those parts are so I can avoid them?
