Rusty's Arms
Old Dec 13, 2007 | 06:17 AM
brianb1222's Avatar
Default Rusty's Arms
I Was Looking At Rusty's Offroad And Saw There Control Arms But Have Not Heard Anyone W Them. Does Anyone Know How Good They Are Because They Are Very Reasonable In Price.
Old Dec 13, 2007 | 08:28 AM
brianb1222's Avatar
ANYBODY?
Old Dec 13, 2007 | 08:48 AM
WestGaParrotHead's Avatar
I'll chime in.... I havent seen their products for the JK. BUT I had their 4" lift with all of their arms on my old XJ... and the damn things were stout... 2.5" OD .120 wall DOM tubing (if I rememeber correctly). Thing with rusty's is that they reused the factory rubber bushings instead of going the super joint / johnny joint / heim joint route... which is no biggie.....
Old Dec 13, 2007 | 01:14 PM
BLKRuby's Avatar
The Rusty's don't have the fancy joints like others, but they are still flex joints in the fact that they will rotate on articulation. I have seen them on XJ's and must say they are very heavy duty. I wouldn't hesitate on putting these under my Jeep, just don't have the money.
Old Dec 13, 2007 | 01:48 PM
Lorrel's Avatar
Although I can't speak for the JK parts, I too have Rusty's lower arms on my 6"JK. As a matter of fact they've been on for about 10 years now, and except for changing out the bushings once, they've been great. I can't say having to change out the bushings once in 10 years is anything bad.
Old Dec 15, 2007 | 11:10 AM
ralphieboy's Avatar
Thumbs up
Running Rusty's 3.25" lift and control arms and haven't had any problems. If you do get a Rusty's 3.25" kit, at least get the lower front arms so you can adjust the caster without disturbing the axle mount end cut outs for caster cam bolts (the other way to adjust caster). You need to get the correct caster adjustment or you will be all over the road trying to keep up with the wandering!!!
Old Dec 17, 2007 | 08:50 AM
brianb1222's Avatar
does it flex alot? and also are good on the road?
