Sagging front coils, replacement advice please
I've got a tf leveling kit, flats and 35's. The kit worked great and looked fantastic but when I put my or fab stinger and winch on it sagged me back to stock height. What are my options? I'm looking for a 2 inch over stock gain after compression from the bumper.
I was thinking of using ome hd front coils but I was worried about having two different spring rates. What do you guys think? I'm looking to keep an LCG setup. Minimal lift, mild bumpstopping. I won't be going to a bigger lift until I can run 40's.
i would go with the med duty ome springs front and rear as well as the long travel shocks from them. you will be happy with the better ride and flex offroad.
if you only have the money for just fronts you will be fine till you buy the rears. they are not to much for the set. call up david at northridge 4x4 and he will hook you up. link in my signature
you can run 40's with the ome hd ltr lift that is 3" of lift. med duty will be close to 2"
