Sail panel tie up
Old Aug 10, 2008 | 04:04 PM
sasquatchpoacher's Avatar
Default Sail panel tie up
anyone know if they make anything like this for 4dr JK's? or has anyone come up with a homemade solution?
Old Aug 10, 2008 | 04:19 PM
mikeyfl's Avatar
i saw a thread about this for a two door. ill see if i can find it.
Old Aug 10, 2008 | 04:22 PM
Robar's Avatar
http://www.quadratec.com/products/91109_101_07.htm
Not sure if it works with both the 2 and 4 door.
seer1's Avatar
I'm going to start looking at this. Clover Patch says only for two door as the roll bar is too far away. I'm wondering why they can't be attached somehow to the rear bow. I'm tired of branches pulling them off the back.
Old Aug 10, 2008 | 04:34 PM
JK-KJ's Avatar
so this is supposed to stop the annoying flapping sound when the top is up and the windows are out? what's to stop the straps that put tension on the top from flapping and making the same noise?
I run around with my top up and windows out all the time, and the flapping isn't a big deal to me...
Old Aug 10, 2008 | 05:52 PM
Propilot512's Avatar
Can any one explain how this works, my soft top sail panels are hard and I cant see how you roll them up. I have heard some soft tops the sail panels are not ridged. Is the panels removable or something.
Old Aug 10, 2008 | 07:32 PM
seer1's Avatar
With mine, I run some tight trails and branches keep pulling them out. If I put the top down, it becomes a real problem grabbing my gear out of the Tuffy drawer. Finding some way to tie them up would really take care of the problem. And yes they are really hard. It does seem like they'd be damaged if they were rolled up.
Old Aug 11, 2008 | 05:07 AM
YellowToy's Avatar
Here's the link to a home-made version. I plan on doing the same next month & will post a full write-up then.
https://www.jk-forum.com/forums/jk-show-tell-33/safari-top-mod-36092/
Old Aug 11, 2008 | 05:31 AM
seer1's Avatar
https://www.jk-forum.com/forums/showthread.php?t=36092
Thanks!
