School me on Tie Rods
Old Nov 5, 2019 | 04:21 PM
kwhit83's Avatar
Default School me on Tie Rods
Noticed today while installing my new Crown Auto TR that one end has a castle nut and the other end has a lock nut...also the end with the castle nut has a zerk fitting, the other end does not. Got me wondering why?
Old Nov 5, 2019 | 05:22 PM
Mr.T's Avatar
Community Favorite
Probably different designs from different manufacturers. Curious if they have where they are made printed on something, or any other identification?
Old Nov 6, 2019 | 02:22 AM
karls10jk's Avatar
That is odd- I've always seen castle nuts on the tie rods and suspension components in general (drag link and ball joints come to mind). Is there a hole for a cotter key on the non- castle nut side? Also- is it a nylock nut or is it one of those tension ones where it's stamped? Either way, I would prefer the safety of the castle nut and key.
Old Nov 6, 2019 | 02:31 AM
kwhit83's Avatar
there is no hole for a cotter pin on the non castle nut side......also it is a nylon lock nut.
Old Nov 6, 2019 | 02:41 AM
karls10jk's Avatar
I just did a quick search and apparently it's not uncommon to have a nylock nut on there. I think I'd personally rather have the sense of security with a castle nut but Crown Auto who makes factory style replacement pieces (style, maybe or maybe not quality), has nylock nuts on both ends of their rod.
Old Nov 6, 2019 | 07:05 AM
Rednroll's Avatar
Can you still return it?
Old Nov 6, 2019 | 07:33 AM
kwhit83's Avatar
There is nothing wrong with the TR itself...just had me wondering why it’s like that. I’m a newbie at Jeeps so I like to ask a lot of questions...wasn’t sure if this was normal
Old Nov 6, 2019 | 08:37 AM
resharp001's Avatar
Loved
Community Favorite
Something seems fishy. Everyone focusing on the nut, but the fact that only one end has a zerk doesn't seem right. Almost like someone bought that, removed an end, screwed a different end in and returned it. idk....but something isn't right.
Old Nov 6, 2019 | 10:23 AM
Rednroll's Avatar
If it's using a castle nut without a hole in the rod to put a pin through it to prevent the castle nut from rotating, then that's either a really bad design or something isn't right where either way, I would return it.
The different ends sounds fishy as well, but without seeing if they're using 2 different types of joints, it's hard to say since I've never seen a Crown TR in person. Typically Crown makes OEM knock-off parts and when I look at the pic below of the Crown kit, it sounds like you may be missing some parts, such as a tie rod end.
The bottom rod in the picture below is my stock TR which I replaced. So looking at that picture above of the Crown kit, that bottom rod looks like the TR....but it looks like it needs that TR end underneath it.
Old Nov 6, 2019 | 10:30 AM
resharp001's Avatar
Loved
Community Favorite
There's nothing wrong with asking questions at all, that's the best way to learn; however, everyone here is raising red flags.
