Screamin demon wires and coil?
Old Nov 29, 2010 | 09:16 AM
Default Screamin demon wires and coil?
Just would appreciate some feedback, views and thoughts on these please?
Thinking of upgrading to these. How about it?
Old Jan 25, 2011 | 08:45 PM
goldieexpo's Avatar
Bump! Mee tooo!
Old Jan 26, 2011 | 04:29 AM
T&ERun's Avatar
They won't add any power. Many of these companies advertise they do, but they really don't. The quality of the wires should be great though. They have been around for awhile now and make good stuff.
Old Jan 26, 2011 | 05:34 AM
Thank you for your input.
Old Jan 26, 2011 | 08:41 AM
A/C Guy's Avatar
Some aftermarket wires have less resistance (you're thinking "awesome", but wait- there's more!) These wires with less resistance can actually interfere with your radio signal and cb signal if so equipped.
The better wires have less resistance and do not interfere with radio reception.
The factory wires are really cheap and poor quality. I replaced mine after 10,000 miles to prevent any issues.
Old Jan 26, 2011 | 11:34 PM
yellow08rubicon's Avatar
I just did these Livewires, Screamin Demon Coil, and new Plugs. I am now getting about 10-20 more miles per tank. I can't say I felt any power gain but I will say it just feels smoother all together. Considering their coil costs exactly what a new one costs from autozone I didn't feel that bad about the purchase and now I have an extra coil lying around (Factory One) should this one ever go bad.
Old Jan 27, 2011 | 12:45 AM
highoctane's Avatar
You MAY get slightly better fuel economy, like mentionedabove, 10-20 miles per tank or so. The hotter spark will give more complete combustion, but any increases in power on such a small, low power engine will go unnoticed since it'd be so small, if any.
Old Jan 27, 2011 | 01:57 AM
toymaster's Avatar
If you are doing it for a performance gain I would not. They are around $190 and you will not notice any difference. On the other hand, if your coil went bad or you need new wires then why not. There is nothing wrong with dressing up your motor with matching color wires.
Old Jan 27, 2011 | 04:11 AM
T&ERun's Avatar
You may have seen the milage increase by putting stockers back in too. Your old plugs and wires were probably worn some.
Old Jan 27, 2011 | 04:57 AM
I guess it's possible but I doubt it. I put 37's on my Jeep when it had about 12,000 miles on it and it has almost 50,000 now and I have always got around the same amount of miles per tanks. The only time I have seen a difference was when I did headers (a little extra) and now when I did the ignition. The biggest benefit is I don't have to worry about burning the factory junk up with aftermarket headers, these can take a lot higher temps than the factory wires.
