Screw in wheel stud torque specs
Old Jun 18, 2015 | 06:41 PM
D_engel's Avatar
Default Screw in wheel stud torque specs
Looking for some help from those who run chromo's. Just got my G2 rear shafts today which came dual drilled for screw-in wheel studs. Problem is, there is no info on torque specs to be found. Anyone have some insight into what I should torque 'em down to?
And don't worry, I plan to use some good 'ole red loctite during assembly.
Old Jun 18, 2015 | 07:11 PM
Invest2m4's Avatar
This isn't fact, but I would guess it is the same as installing a high steer arm. Hand tight or 5 ft lbs.
Old Jun 18, 2015 | 07:18 PM
D_engel's Avatar
they are a hex bolt that thread from the rear. I figured they'd back out first time I went to tighten a lug unless i had them set anywhere over the factory 95 lb's. Kinda stumped on this one
Old Jun 18, 2015 | 07:25 PM
ronjenx's Avatar
I did a search for screw-in studs and found 90 - 95 ft/lbs with red locktite to be common.
I'm surprised the shafts didn't come with instructions addressing this important point.
I would call the manufacturer and see what they say.
Old Jun 18, 2015 | 07:31 PM
D_engel's Avatar
Thanks guys. I shot them an email so I'm waiting to hear back from them.
Old Jun 19, 2015 | 05:58 AM
Invest2m4's Avatar
Oh, I was thinking an actual stud. Yeah, torque spec is usually based on bolt size, grade, and pitch. 90/95 should be about right.
Old Jun 19, 2015 | 09:39 AM
D_engel's Avatar
Yea that's what all my research is telling me. I run spacers so I really only need to get everything torqued down properly once, then its just maintenance.
Old Jun 19, 2015 | 09:44 AM
Invest2m4's Avatar
I really wouldn't think much about it. Even if a wheel falls off, you still have three good ones left. Just be sure to turn into the direction of the side the wheel fell off
Old Jun 19, 2015 | 12:04 PM
D_engel's Avatar
Bailing wire and duct tape should be enough to reattach a lost wheel, right?
Old Jun 19, 2015 | 03:29 PM
Maertz's Avatar
If by screw in you mean weld in i wouldnt worry...so id try welding it with a welder.. Lol cheers man
