Sector Shaft braces?
Old Dec 21, 2014 | 05:29 PM
mattgt5's Avatar
You are correct. Two pieces.
sent from my work leash
Old Dec 22, 2014 | 07:38 AM
andore's Avatar
Yeah I know you said you had tried the Synergy but wasnt sure if it was maybe just an issue with your particular set up so i thought i would get some more opinions. Its going to have to be RSP apparently.
Old Dec 22, 2014 | 07:48 AM
jnabird333's Avatar
I have the Synergy one and a Metalcloak Track bar. It works fine with this combo.
I do have very slight spring contact (MC 3.5" coils) at full stuff and the flat on the sway bar needed to be extended to clear the bracket.
I would go with this one again...
Old Dec 22, 2014 | 12:43 PM
sea bass's Avatar
Originally Posted by jnabird333
I have the Synergy one and a Metalcloak Track bar. It works fine with this combo. I do have very slight spring contact (MC 3.5" coils) at full stuff and the flat on the sway bar needed to be extended to clear the bracket. I would go with this one again...
Got any pics of the issue?
Is there any way to grind or modify to avoid contact?
Old Dec 22, 2014 | 12:46 PM
Invest2m4's Avatar
Originally Posted by sea bass
Got any pics of the issue? Is there any way to grind or modify to avoid contact?
I had the same issue, but I couldn't solve it.
Do not grind the coil though.
I'm not quite sure why people avoid the RSP brace? It fits and works great.
Also, I had an issue on the Synergy brace where the track bar hole was about 1/4" off. That's another not uncommon issue with them.
Old Dec 22, 2014 | 02:00 PM
jnabird333's Avatar
Correct! I did round the sharp edge of the brace some and it helped on the spring rub, but it isn't fully gone. I will try to grab some pictures of this and the sway bar mod tomorrow.
I didn't avoid it... I just didn't know about it when I purchased the Synergy one. My Trackbar hole lined up but I have heard of this being an issue as well. I do tend to stick with what I know though...
Old Dec 22, 2014 | 02:27 PM
Rock Krawler Suspension's Avatar
Former Vendor
Originally Posted by andore
Ive looked around at a couple threads, still kind of unsure, but is anyone running the synergy sector shaft brace and a jks adjustable trackbar? Im looking for a sector shaft brace and was looking at the synergy, but read it wont fit some trackbars? I was also looking at RSP's but its $100 more. If i can run the synergy that would be preferable. Thanks guys!
Like the guys here are saying there can definitely be some contact with the coils depending on the OD of the coil and the wire size used. We have seen the best luck with the RSP sector shaft brace in the past.
RK
Old Dec 22, 2014 | 02:51 PM
sea bass's Avatar
I had the same issue, but I couldn't solve it. Do not grind the coil though. I'm not quite sure why people avoid the RSP brace? It fits and works great. Also, I had an issue on the Synergy brace where the track bar hole was about 1/4" off. That's another not uncommon issue with them.
I know - I just like the idea of having the tb brace.
I'll likely end up going with RSP as well just to be safe.
Old Dec 22, 2014 | 05:09 PM
Rebar-7's Avatar
Ha.. I went on RSP's web site last night after Invest told me who they were, only to
Find that their web site is down for maint and closed for the holidays...bummer....
Old Dec 22, 2014 | 05:25 PM
Wightmn's Avatar
Running synergy sector shaft/track bar brace and MetalCloak Trackbar on 3.5" lift. Only difference is I've got Artec high steer kit. No contact on mine. Works great.
