Security Box (Diamond Plate)
Old May 1, 2013 | 07:42 PM
Long_Island_JK's Avatar
Default Security Box (Diamond Plate)
I wanted to add a bit of security to the trunk for the topless season but I didn't want to go over the top. I looked into several truck security options many seemed either expensive or to be not too effective so I went with this.
I purchased a UWS Diamond plate toolbox 32x12x12, several L shaped brackets and hardware.
The rear of the truck has two clips that are fastened to the bed with a bolt. I simply removed the clips put the bolt through the L brackets and fastened it to the box. 4 brackets total, 2 each side, one within the box and one on the outside. I used bolts that require an allen key so its to super easy to remove. Not 100% safe but good enough to throw in items such as back packs, tow straps and whatever you don't want flying around in the wind.
Old May 1, 2013 | 07:50 PM
ID:	453337Click image for larger version
ID:	453338Click image for larger version
Old May 1, 2013 | 10:54 PM
GunDude's Avatar
Pretty much what I did, as I did not like the Tuffy Security deck I had installed. Except I mounted mine over the rear seat brackets, cut two holes in the bottom of the box and used to adj. bolt to hold in place. Will take pics when I get home and it is light.
Old May 2, 2013 | 01:16 PM
GunDude's Avatar
Just an update to secure a tool box in the back, that is if you do not need the rear seat. It takes longer to empty the box than it does to put in or remove.
ID:	453517   Click image for larger version
Old May 2, 2013 | 02:07 PM
jlmo's Avatar
I have an aluminum box that I secure using the existing holes from inside the box.
